library block preview pane
Hi Guys
When I select LIBRARY and toggle SHOW BLOCKS I get the list of all the blocks in my library , but the preview pane is no longer visible and I cannot work out how to get it back.
It was working perfectly recently and to my knowledge I haven't done anything to make it disappear.
Any ideas?
Cheers
Pete
Re: library block preview pane
Right mouse button click in the white space where the files are listed in the pane and select "Preview".
Production: ST10 MP7
Testing: SE 2019
http://Grundey.blogspot.com
Hi Ken
thanks heaps, can't believe I didnt stumble over that as I was right clicking all around there.
I'm back in business Woohoo
Cheers
Pete
same problem: was there, switched off, no preview option in right-click menu Smiley Sad
pls hlp
Do you have a picture of it ?
Capture.JPG Hi you maybe right clicking in the wrong field. Have a look at the photo and right click in the field at the top left of the pop up menu with preview ticked
Cheers
Pete
