license ST3 license ST4 expired at the end of april 2015
Siemens Creator
the licenses pointed but he links (on the french web site)
Licences seules
Licence ST 3 (1 KB)
Pour les clients existants. Utilisez uniquement cette licence pour mettre à jour ST4 ou les versions suivantes.
Licence ST 4 (1 KB)
are expired at the end of the month
INCREMENT solidedge2ddrafting sedemon 103.0 30-apr-2015 uncounted \
 FDD23E4692FD HOSTID=DEMO ISSUER=SIEMENS
Do you plan to give new licenses before the end of the month ?
thank you
Re: license ST3 license ST4 expired at the end of april 2015
Stephanie,
Licenses for Solid Edge 2D Drafting ST3 will be made available by request only. The license will no longer be available on the download page.
Rick B.
Hallo,
i have the same Problem with ST6, German Version.
It will expire in 23 days.
Where can i get an new licence?
I will continue to use ST6 becaus 32bit.
Regards.
Salvatore
@PlexiWorker wrote:
Hallo,
I have the same Problem with ST6, German Version. It will expire in 23 days.
Where can i get an new licence? I will continue to use ST6 becaus 32bit.
Regards.
Salvatore
Hi Salvatore,
You can go to the Sollid Edge Free 2D page [here] on the right side there are options for upgrading your version & renewing the license.....fill out your details on the registration page....then on the download page, you have a special section for a "License Only" upgrade, for users on ST4 onwards. [further instructions are in the downloaded file there]
Testing: Solid Edge 2019
Hallo Sean,
I works !!!!
Thank you for the tip.
Salvatore
You are very welcome....happy Edging. Robot Happy
HI!
Could you please tell me where do I can make a request for solid edge st3 licens file (free 2d draft). You wrout in the forum that it will be aviable only on request? I tried to write to the support center bun no one has answered for weeks now...
Siemens Creator
I got mine from ricky black, the webmaster, I am sure he will reply to you soon !
Cheers
Thank you for the Information.
I've got the Licence File from the English Download Site.
We use ST6 free 2D
Cheers
Hi there,
Might I also recommend, you SAVE a copy of these [License File & Installation File] to some sort of removable storage, so you have it to load & reload at your leasure.
