license file failure ?
N/A
I have installed SE 2D Free a year ago, and got a message now that I needed to download a new licence
Have done so, extracted and filed in program/license
However, program failes to statrty and I get themessage again that I should download a need license
After trying 2 x I have erased the program, downloaded a new one, plus new licence
however, still same problem.
can you help me out ??
Thnx Rob
Re: license file failure ?
N/A
Rob,
Have you at some point changed your system date?
Our license checking will detest a system date change.
Rick B.
N/A
I was having the same problem. Relized my computer was a month behind. Poof now it works. Thanks,
[langtitle=fr]Re: license file failure ?[/langtitle]
N/A
Bonjour
Même probleme, lisence chargée plusieurs fois et toujours le même message: il fut mettre à jour la lisence, pouvez vous nous aider, merci
N/A
Same problem here - new downloaded licence doesn't work with newest Solid Edge 2D Drafting ST2 Smiley Sad
HELP!
N/A
If you download and install the latest version, you do not have to worry
with the license.
The software will install the most up to date license for you.
I'll ask the same question I asked before on this thread.
Have you changes your system date?
Rick B.
N/A
Well,
I downloaded the most actual file. Installed the License.dat as described and got the error message as mentionend by other users. No time changed. Time is synchronized with NTP.
So, Time/Timezone/Date is correct. What to do now?
regards,
Marco
N/A
Same problem here. No date changes.
N/A
Guys,
Do the following.
Open a window and navigate to the C:\WINDOWS directory.
Sort by date with the most recent files at the top.
Do the same for C:\WINDOWS\system and C:\WINDOWS\system32
See if there are any files with the date in the future.
Rick B.
N/A
Guys,
Open your 'My Documents'.
Go to 'C:\WINDOWS\'.
Search for '*ACRORD32.exe*.
Include the * before and after the filename.
Look at the dates on what is listed.
Let me know what the dates are.
Rick B.
