license key not mailed
N/A
Hello
I have just downloaded and installed the solid edge ST4 version. However, I did not receive the following mail with 12 character license key. This issue is not letting me access the software.
All I have is an initial e-mail with the download link and username and password for dedicated student's support forum.
Can somebody help me in locating the license key.
Re: license key not mailed
Esteemed Contributor
Hello
Hi there,
You "should" have it already, with the email you recieved containing the download link....including instructions on how to install it.
Good luck.....& enjoy. Smiley Happy
Solid Edge ST10 [MP6] Classic [x2 seats]
N/A
Hi there,
This is the attachment looks like SELicense_8651.txt and this is what is in it.
INCREMENT solidedgeacademic selmd 104.0 01-jun-2013 uncounted \
VENDOR_STRING="SOLID EDGE ACADEMIC COPY" HOSTID=DEMO \
ISSUER=SIEMENS SIGN="1A40 E605 46F6 E288 765D 94F8 63E4 BE2F \
3EE9 2A4A 1BEC 2657 8339 29C8 4117 1DA8 6256 6B5B 1A14 1040 \
1781 5AB7 40B5 930C AE22 FB2A 4198 7405 F2D1 666D"
When I click the SELicense_8651.txt which 12 characters do i choose.
SELicense_8651.txt and this is what is in it....which 12 characters do i choose.
OK, so....DO NOT edit the content of this file.
It is accessed from the file, by the Solid Edge program at every startup.
But rather...
"SAVE" that .txt file to your desktop, but rename it to "SELicense.dat" (make sure you have your "Hide Known File Extensions" un-checked...else it will hide an additional extension)
Then run the Solid Edge License Utility....to load the file.
*Alternatively, you can "Copy" the file to you installation folder, usually.... C:\Program Files\Solid Edge ST4\Program ..."Paste" it there, and overwrite the existing, if it asks.
N/A
Thank you so much,,, it worked...
Glad to hear that.....have fun.
Maybe post a few pics of your creations sometime.
N/A
Thanks but finding difficulty in getting started need tutorials
Hi there....you can find tutorials in the help menu, found at the top right side of the Solid Edge window, as pictured here...
