license problems
N/A
it says when i try and open solid edge that i need a license for first time use but when i try and open SELicWiz it says that the solid edge license file is already in use and to close the current solid edge program and restart the license utility, yet i don't have anything open
Re: license problems
N/A
ST5 student free version works only if you install it in the system you downloaded. it won't work in any other computer.
Esteemed Contributor
The license file is located in a protected folder and is read only to the user by default. Installing and then running with User Account Control off my resolve this, or change the security setting on the file, or install to a location outside of "c:\program files".
Production: ST10 MP5
Testing: SE 2019
