link not active
N/A
the link they sent me in the email isnt active. what do i do
Re: link not active
N/A
Cody,
If you try again after a while, as they may have reset the server...just guessing???....but otherwise, I'd just go through the whole process again, and you should get a new link & license file.
Sean.C
Re: link not active
N/A
Read this and try the link that i have given...
Siemens ask for student registration before downloading. After registration, they send a link to your email id and also SE License.txt as an attachment to the same email. The link provided into email from Siemens is valid for download in 24 hours only : just check that link carefully... it will contain following link as a part of download link...
if you want to download solidedge st4 directly and in more than 24 hours(especially when using low speed internet), then use this link (paste it in browser address bar) :
http://dl2.plm.automation.siemens.com/solidedge/SolidEdgeV104ENGLISH_32Bit.exe
address in above link (after http://) : dl2.plm.automation.siemens.com/solidedge/SolidEdgeV104ENGLISH_32Bit.exe
and don't forget to get valid student license for above copy of st4, by registering yourself on siemens website... ignore if u have received license... license file do not have 24 hr restriction....
hope you will be able to download st4 now...
