looking for methods for quick 2d joinery
Builder
Builder
Hi there,
I'm using Solid Edge to build my flat-packed items that we cut on a CNC router or a laser cutter. The only issue I'm having is joinery. It takes a *really* long time to draw in the joinery in each part. It's to the point where it can take 20 minutes to draw the part, and an additional 4-5 hours to create the joinery. Has anyone here had any luck speeding up this process?
Is Solid Edge not the right tool for this job?
Luke
Re: looking for methods for quick 2d joinery
Esteemed Contributor
Hi Luke,
Look under help, for the topic "Feature Library"....seems this should do what you're looking for.
Builder
Builder
Hi Sean,
I can't seem to find the feature library tab. The help section mentioned
it, but when I go to View > Show > Panes, no feature library tab comes up.
Any thoughts?
Luke,
If it doesn't appear as it's own tab, then you may have inadvertantly removed it.....you can turn it back on, on another tab there is drop-down that should have it listed, selecting it should reinstate the tab.
Builder
Builder
I found it, I was trying to access it from an assembly.
So I get the idea behind the feature library, but I'm having a horrible
time getting it to do anything faster than I already can.
I need to "paste" these extrusions on an "edge face" so that they are
symmetrical. (The center extrusion's center is coincident with the center
of the edge face)
Can you show a pic of what you are trying to do?
Production: ST9 MP10
Testing: ST10 MP3
Builder
Builder
Hi, sorry, I thought I did post a pic. Here we go:
https://dl.dropboxusercontent.com/u/23865811/box%20-%20spine.jpg
I guess I'm still not understanding what you are trying to do.  Not seeing anything that should take several hors to do, so I guess I'm missing the big picture.  When you say "joinery", I have no idea what you mean by that, and I'm assuming whatever you are making has to be shipped flat and assembled by the customer???
Testing: ST10 MP3
Builder
Builder
Here's a quick video. Thanks Smiley Happy
https://www.youtube.com/watch?v=c_gvInhc-do
Honored Contributor
Honored Contributor
In general, I'm guessing your not taking advantage of the relationships between sketch elements. If you take advantage of setting line segments = to each other, and learn to copy and past sketches you could get that done quickly.
