mass units
I'm doing a drawing and I need to put the mass in the parts list. The problem is that it comes in Kg and my pieces are to small. How can I change to g?
Re: mass units
In your draft document go to File Properties (Application Button-Properties-File Properties). Select the Units Tab and then select the Advanced Property button. You will see Mass in the left column under Name. Click Kg in the  value column and you will see a pulldown arrow where you can adjust the units to Grams. You can also adjust the precision as required.
After setting as desired, click Ok twice to return to the drawing sheet. Click Update All in the Property Text Tab and your mass should update accordingly in the parts list.
HTH,
Bob Henry
Bob Henry
REH Technical Consulting
Canonsburg, PA 15317
Re: mass units
I have tryed it and it worked well. Thank you for your help
