measurement blue and not changeable
when i start a new part i sketch a square and put on 1 measurement but it shows up in blue and when i change the measurement the line does not adjust to the length i type in. The only thing that happens is the measurement gets a underline
Re: measurement blue and not changeable
you need to toggle that dimension to a driving (red) dimension.
Select the little lock icon to the right of the dimension input box.
Unlocked = Driven dimension (reference dim)
Locked = driving dims
it does not work it is grayed out
In the "Relate" section of your ribbon, turn on "Maintain Relationships".
http://Grundey.blogspot.com
thanks Ken,
I knew it was one of those setting but i tunred off automatic update on my machine and tested and it still worked so i knew i was wrong and was waitign for one of you all to jump in ,,...  thx for the reminder.
