model an eccentric reducer
How does one model an eccentric weld reducer?
Hi there,   I use a group of sketches to achieve this.......
Hi there,
I use [an ordered approach] a group of "sketches" to achieve this.....major & minor diameters spaced apart, and upper [used a spline curve with added control] & lower guide curves, then "blue surf" applying the guide curves, then the "thicken" command.
EDIT: of course, then add the chamfer to both outer edges.
[attached is the ST6 part file I just bashed together, so may not be accurate]
Testing: Solid Edge 2019
