modify frame
Hello all,
I  have successfully created a frame and I want to modify the cross-section of the frame.
Therefore I thought to exchange the part-file against another one.
1) I tried right clicked "edit definition" on FrameComponent/Frame# within the path-finder, to modify the contents of the existing item Frame Component/Frame#. But this way I only have the option to edit the frame's path but cannot choose the cross-section file.
2) Another approach was to generate a new frame_component in the path-finder's list of frame components and could compare the results to find out, which looks better. But here I found, that I only could generate a new frame component, if I deleted the other frame component with the identical path before. Is that an expected behaviour?
Which way would You suggest to modify the cross-section of an already generated frame?
best regards
Hans
Betreff: modify frame
I attach for illustration this video
(view in My Videos)
