moving a drawing to a separate sheet
N/A
Not sure if this can even be done. I have a drawing I made with a number of different
parts about 12 all on one sheet which prints out 8 1/2 x 11 so the parts are to
small to read easy. With 3 views of each . Is their a way to select them and get
them to move to a new drawing with just the one part 2 are 3 views on 12 separate
sheets are drawings.
Re: moving a drawing to a separate sheet
N/A
I assume they are drawn on the model sheet. If they are then just put them on separate
drawing sheets. If you drew them all on one drawing sheet select them all and copy
and paste them to the model sheet. Then you can put them on separate drawing sheets.
I may not be understanding your problem completely so this may not be what you are
looking for.
Ed
>different
>are to
>get
N/A
>on separate
>and copy
>sheets.
>you are
>looking for.
>Ed
>of
>>different
>>are to
>and
>>get
>separate
N/A
>>on separate
>>and copy
>>sheets.
>>you are
>>looking for.
>>Ed
>>of
>>>different
>>>are to
>>and
>>>get
>>separate
Let me try again The drawing is on a D sheet finished I cant find a way to pull
up a new sheet and move any thing . I did figure out how to draw on working sheet
and move that to a D sheet are back and forth. But when I pull up the drawing their
is nothing to click on for more sheets. Hope you get this.
N/A
Lane,
Can you attach the file to your response and maybe we can figure it out for you?
Ed
>to pull
>sheet
> their
N/A
Lane,
I think there are multiple questions here. So I will try to to give multiple
answers.
You can create more sheets by simply right mous button clicking on the
Sheet1 tab at the bottom and then click on Insert. This inserts a new sheet.
If you need to change the size if an existing sheet, righe mouse click again
on the Sheet1 tab and click on "Sheet Setup...". Look at the tabs in the
dialog.
If you need to move something from one sheet to another sheet, select what
you want to move. Copy what you have selected. Go to the other sheet and
paste the geometry.
I hope this is what you are needing.
Rick B.
