mr
Not applicable
Please help! When I open free2d to install it, it keeps on saying that file is corrupt. I already download the program twice. Thank you
Re: mr
Are you saving the file locally to your machine, or running directly. When you click to download, you will be given a choice. You will have better luck if you save the file locally to your machine. Then you have a chance to run it after the download. When the download finishes, check the size of the file to ensure that the download was successful. It will be around 450+MB.
Rick B.
Re: mr
Not applicable
Hi Rick.Hi saved it twice localy. It is Zip files and it is about 450MB.When I want to install
it, it don't want to Extract files and said it is Corrupt.Tanks for reply.braam
Re: mr
I don't understand when you say you 'don't want to Extract files'. Extraction is part of the installation. All it does is unpackage the installation files to a temporary location so that it then can be installed.
Rick B.
Re: mr
Not applicable
I downloaded the program and saved it on my laptop. Now I want to install the program,
it starts to extracting the files and then stops.It say that the files are corrupt.I have windows Xp on my machine. I downloaded twice because I thaught it didn't downloaded correctly, but both are the same.
Braam
Re: mr
Which language are you trying to download? I'll try to download and install it.
Rick B.
Re: mr
Not applicable
Same for me. "file corrupt" message when the file is being extracted. Using XP. File size at file manager: 459 994 kB,
at file properties: 449 MB (471 033 216 byte), on disk: 449 MB (470 994 944 byte)
/Kenneth
Re: mr
Kenneth,
Do you have administrator privileges?
The executable will unzip to a temporary forder so that installation can begin.
Rick B.
