needing information on where to look for this error for error assistant
Ok great minds.
I have been working on this enclosure until I cant stand it.  Me and another co worker are at a loss and just paddled on with it.
The error assistant must have gone AI on us.  All of my parts are correct and I have them in the correct places so there must be something that is missing from somewhere.
I need to know if there is a better way for the error assistant to locate, find or show us a way to make sure that the "error" in question could be nulled.
When I open up this assistant, there is nothing there that shows up.  Any ideas?
Thank you for your time.
Re: needing information on where to look for this error for error assistant
not seeing the error asst in your screen shot?
need a little bit more info.
a video showing us what you are seeign would be helpful.
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
totally weird, i reopened the application to open the enclosure and get a vid ready, it is gone.  i closed it and reopened it several more times and it is not there.
Anyway thank you for your support.
