no puedo realizar un solido en la version estudiantil ST6
21 REPLIES 21
Re: no puedo realizar un solido en la version estudiantil ST6
Siemens Legend Siemens Legend
Siemens Legend
Hi @jaavii22
What operating system are you running?
Melanie
se ejecuta el de 32bits
Siemens Legend
Which version of Windows?  7, 8, 8.1 or 10?
version windows 10
Siemens Legend
Solid Edge ST6 is not supported on 32-bit Windows 10.  It is supported only on 32-bit versions of Windows 7, Windows 8, and Windows 8.1.  For Windows 10, we support only 64-bit (and ST8 or later).
aqui esta el archivo crashlog.txt
Firstly based on the crashlog you are running Windows 8.
Secondly, your page file size is incorrectly set.  For Solid Edge we recommended setting it to 2 x RAM.  Please see the provided attachment on how to correctly set your page file size.
Thirdly, make sure you have run Windows Update to ensure that you have the latest fixes installed.  When checking for the updates makes sure you check online from Microsoft for the updates and take *all* of the updates.
There is more we can look at but start with this and then we can revisit if necessary.
he realizado todo lo que me has dicho y a un sigue saliendo el error
Can you psot the latest crashlog and provide the steps that you are performing to make the crash happen?
