Re: no puedo realizar un solido en la version estudiantil ST6
Aqui tiene el ultimo crashlog.txt
Hmm, this log is still only showing 3.99 GB for page file size.  Did you follow the instructions I provided previously on setting the page file, and once set did you leave the file set to 8 GB?  Please provide a screenshot of your Virtual Memory setting e.g.
Also, you did not provide the steps you were taking leading up to Solid Edge crashing so this will make it more difficult to debug and provide you with a  solution.
With that said, attached is a registry file saved in a Zip.  Please download this file to your system, extract the content, and then with Solid Edge closed double-click on the .reg file to install the settings.  Then try opening a Solid Edge model again.
@uk_dave Could this be a graphics card issue if it is crashing when opening a Part template?  Guessing the graphics aren't stellar either on this PC...
http://Grundey.blogspot.com
A un me sigue saliendo el error
porque lo rraro es que puedo realizar y abrir planos
Can you open a DFT file without crashing?
I'm suspecting graphics card issues.  Not sure what graphics adapter you have, but make sure the driver is up to date.  Also, please let us know the brand and model name of your graphics adapter.
En El Ordenador tengo puesto m Una grafica gigabyte GTX 660 2GB GDDR5 de Nvidia
@KennyG I also suspect it is graphics card related.  The registry file I provided earlier was to set the graphics to backing store .
@jaavii22 My apologies.  The registry file I provided you with previously was for ST8.  Please find attached a new registry file for ST6.
Please download this ST6 compatible file, unzip it, and with Solid Edge closed, please double-click on the extracted registry file to install the settings.  Then start Solid Edge. Hopefully this will then resolve your issue.
el error a un aparece.
