open Autocad .dwg file
N/A
I've been unable to open the attached file using the free 2D program or Solid Edge
V18.
Re: open Autocad .dwg file
N/A
Mark,
I was able to open the file. See attached image.
Ed
>Edge
>V18.
N/A
"Ed Kadlec" wrote:
>Mark,
>Ed
>>Edge
>>V18.
> OK, obviously I'm not doing something correctly. Would you walk me through set
up and anything else you think I might be doing wrong?
Mark
N/A
"Ed Kadlec" wrote:
>Mark,
>Ed
>>Edge
>>V18.
>Never mind. I finally got it. Never over look the obvious.
