outside flanges
I have a sheet metal pan with two flanges bent 45 degrees out. What i'm trying to do is close them up to form a outside miter. Is this possible? I'm using solid edge st5.
Joe
Here is my file. Thanks.
Joe
Easiest way to do this is with "Contour Flange". Draw the...
Community Manager
Easiest way to do this is with "Contour Flange". Draw the base plate that will be the bottom of your pan. Then, from a "side view" you will draw the 45 degree line and then use Contour Flange to go around the part. It will do the miters for you and you can define miter options in the options dialog for the command. See help on "Contour Flange" for "how to".
Dan Staples
Re: outside flanges
It seems odd that you can't do this in st5. What would be the other way Dan?
Joe
Re: outside flanges
Esteemed Contributor
Hi there,
I think what you're looking for, is the "close corner" command...in order to do this after the flanges are made.
Sean.
Re: outside flanges
Community Manager
Contour Flange has been there since 1997, so yes, you can do it in ST5 also.
Dan Staples
Re: outside flanges
This closed corner command doesn't seem to work on these flanges because the It says that the bends must share a common face?
Joe
Re: outside flanges
I tried the contour flange. I just wanted to know if you could close the corners to create a mitered flange after the flanges were made.
Joe
Re: outside flanges
Joe, might be a good idea to post a picture of what you are trying to achieve. As Dan said, Contour Flange placed off of the flat plate that defines the bottom should give you what you are after unless none of us are understanding what you want.
Production: ST9 MP10
Testing: ST10 MP3
Re: outside flanges
Sorry guys. I know that you can use the contour flange for this. What I wanted to know was, can this be accomplished without the contour command, just simply close off the corners and create a miter. I just joined, so I don't know how to post a pic or a file. Can someone help me with this?
Joe
Re: outside flanges
You can edit your original question and add an attachment (you can add it on new questions too).
Testing: ST10 MP3
