perfect circle
Not applicable
hi i wish to draw a 2 inch diameter circle in 2d model then place it on the working
sheet and print it on 8.5 by 11 paper. i want to cut the circle out of the paper
that is 2 inch in diameter.
Re: perfect circle
Not applicable
>working
>paper
Not really sure what you're trying to do but if it was me I'd do it like this....
1) Draw the circle on a new sheet.
2) Select it and use the copy command.
3) Open the 2d model sheet and paste the circle on it.
4) Use the move command to position it in place.
Allan
Re: perfect circle
Not applicable
Ken,
I am not sure of what you are trying to accomplish. If all you want is a 2
inch circle on a working sheet, simply draw the circle on the working sheet.
To do what you are asking, do the following:
1. Draw your 2 inch circle in 2D model. Go to a working sheet and place a 2D
model view of the 2 inch circle on the working sheet. Specify a scale of 1:1
when placing the 2D model view. Or change the properties of the view
afterward.
Rick B.
