point clouds in solid edge
Dear All,
Do Siemens have intentions to implement tools in solid edge to import point clouds?
I speak about big point cloud form industrial sites, not about current 'reverse engineering' tools based on STL files.
Those point clouds should work as 'underlayer space' where new design can be build in.
Has Siemens already taken some steps in the case?
best regards,
Re: point clouds in solid edge
Solid Edge doesn't support importing point cloud like NX. It seems this is not a developing direction but Energy industry and others uses this digitalization methode... I think this should be a good direction...
Here is a video, how it works in NX:
BR,
Imics
