problem about display configuration
I saved display configuration in assembly environment, and I created new draft and dropped it. but It displays flipped assembly view. (= ISO View, this is my mistake) how can I draw it properly? (save display configuration, take snapshot function was useless...)
Re: problem about display configuration
I suggest using Modelview (PMI tab) instead of Display config. This is better way for what you want!
Best,
Imics
Here is a short video:
BR,
Imics
Display configurations only control visibility unless you are in the ERA environment where you have saved a configuration for an exploded view. Exploded view configuations maintain orientation.
Bob Henry
Manager of Engineering - Highwall Miners
Caterpillar Global Mining LLC
Houston, PA
