problem about install ST8 (install .net framework)
I have Solid Edge ST8 install CD (includes autostart.exe, etc... )
and installed ST8 successfully.
but .net framework is not exist in my computer
how can I install it ?
Re: problem about install ST8 (install .net framework)
Installing from the autostart.exe menu should automatically check for and install prerequisites. But you can try to install .Net framework manually from one of these subfolders of the DVD:
.\Solid Edge\ISSetupPrerequisites\{32D7E3D1-C9DF-4FA6-9F9B-4D5117AB2917}
.\Solid Edge\ISSetupPrerequisites\{D6B7952E-19E7-4540-8047-AE2D8E091907}
