program crash with 2 d model sheet view in 2d st10
whenever i try to open a file in solid edge st10 that has been saved with a 2d model sheet view, the progam crashes immediatly and the file is lost i.e. cannot be opened again. this is also the case for every file created on previous versions of solid edge 2d.
if the 2d model view is avoided and the file only edited in working sheet view, it can be opened, edited and saved without problems.
a complete new installation of st10 was without success.
System : windows10
thanks for proposals to solve the problem.
Re: program crash with 2 d model sheet view in 2d st10
@Beperes this is a known issue that requires a maintenance pack for ST10 to resolve.
Please check your PMs for further correspondence in regards to this issue.
There is a post at the top of this Community forum titled "Opening Previous Version Files in ST10 - Please Read".
A reply has been posted there explaining how to get an update to Solid Edge 2D Drafting ST10 to resolve the file open issue.
Please go to that post and follow the dorections.
Rick B.
