question about SE wire harness module
The problem what I faced is about wire harness module in solid edge.
Wire harness wizard makes harness automatically, I know.
There are many options about wires, cables, bundles and I have to report(or find) These informations after create it automatically.
Q1. Can I report or adjust wire length between wire and bundle?
Q2. Where is the DETAIL data about Solid edge wire harness module?
I already have seen basic data wire harness wizard pdf file.
