question: how use the PMI annotation in animation?
Hi
i need to prepare a presentation animation of a product in which each part must be described by annotation. the problem is that the annotations don't reposition within the animation. they stick to their default position. is there any solution? is any software for this purpose?
thanks
Re: question: how use the PMI annotation in animation?
What version of Solid Edge are you using and are you using motors/assembly relationships to drive the positions of the parts in the animation?
Greg
Hi
I use solid edge st9.
I've used manual explode tools.
thank you for your hint to use assembly relationships. it works!
Excellent!
