"Parts list properties" gray
I see the "Parts list properties" aren't still ported from ST8 to ST9, but no worries, it was always fixed fast.
I just opened an old draft with the desired properties and saved these settings to a style.
Or I do something different or this isn't possible anymore:
bustpWb
Any idea how to copy my old properties without writing every setting on a paper and fill it in again?
Solid Edge 2019 & AutoCAD 2019 user
4 REPLIES 4
Re: "Parts list properties" gray
Hi @Joris,
That's strange, as it's all I did also......opened previous draft with desired BOM setout, and saved, and it worked.
Do you have read&write permission for reports folder? Check it! Smiley Wink
BR,
Imics
I checked it, but no result.
It is solved.
Thanks to your reply I tested something else.
I copied the folder "reports" to my custom template folder. Now it works again.
Strange...
