"Undo Cache"? Can I increase the number?
Hey.  I'm looking for something like an "undo cache".  Sometimes my document is unable to "undo" and I haven't even saved.  Automatic saving isn't enabled, so that's not it.  I'm thinking the operation was too big to go back?  I'd like to be able to increase the cache size so I can go back on bigger operations.
Thanks.
Re: "Undo Cache"? Can I increase the number?
SE calls it "Undo Steps"
- Application button
- Solidedge Options
- General Tab
     - "Undo Steps" at the top
My number of "undo steps" was set to 500.  That doesn't seem to be the problem.  I wonder if there is a "maximum undo filesize"...
I've had the "Undo Problem" before on certain versions....most likely ST1-ST4. Other than the "Undo Steps"....I dont know....
Hmm.  OK.  I'm on ST7, but still a problem.
certian opperation force a write to disc.  once thsi happens  undo is reset...
Thanks for this.  Man, it seems Solid Edge still has many limitations.
