removes invisable links
in one of my assy i used the Assembly Features to put ahole through a few blocks. my problem comes into play when i delete the feature from one of them. for some reason it say's it's stil linked when it isn't. how do you fix this?Capture.JPG
Re: removes invisable links
Siemens Genius Siemens Genius
Siemens Genius
Can you elaborate on your workflow?
It appears your components are ordered.
I assume you are creating Assembly-driven part features that result in links?
I did the following:
1) Create an ordered block, save as block1.
2) Save as block2.
3) Put both blocks in an assembly.
4) Create ADPF hole through both blocks.
5) Edit one block, delete the hole feature.
6) Open Variable table.
No links were seen.
7) Close and return.
Link icon was gone from the edited block.
I was not able to reproduce.
* Opinions are my own.
Steven Sheldon
Advanced Applications Engineer
Siemens PLM Software
* Opinions expressed are my own.
Does it show up in Tools>Inter-Part Manager?
If so then break it there.
