reset or load default setting in st6
i have made some changes in Solid edge options > vies and colors, but now i want all original settings to be get loaded. how to reset them to default , coz i don't remember original settings now.
you can reset your Hkey_Current user Solid Edge registry....
HKEY_CURRENT_USER\Software\Unigraphics Solutions\Solid Edge
To reset...  simple delete and upon next load of E it will rebuild.
Matt Johnson
Application Engineer
Ally PLM Solutions
matt.johnson@allyplm.com
http://allyplm.com/
Colors is easy to reset because you can just select "Soli...
KennyG 2nd Gear
2nd Gear
Colors is easy to reset because you can just select "Solid Edge Default" from the Color Scheme selector.
Production: ST10 MP3
Testing: SE 2019
