Re: revision delimiter settings
Registry Key is HKEY_Current_User>SOFTWARE>Unigraphic Solutions>Solid Edge>Version 10x>Global "RevDelim"
As always, be careful in the registry if you choose that route.
Okay, found the seadmin.exe, and fixed it. Thanks for helping out!
