revisione
come fare una revisione (modifica) ad un file mantenendo lo stesso nome e mantenendo il file vecchio
Re: revisione
Esteemed Contributor
Hi there,
In this case, I would "Save As" and include the "revision number" in it's file name, in a seperate folder to the working files, for safe keeping. This work easiest with a model only.....we make PDF's of our draft files, at every revision, and just maintain the same models & drafts as they evolve.
Re: revisione
Master
Master
Or use revision manager, select the file en set an action to copy.
Than increment name option and change the revision number
