save as dxf or dwg
Not applicable
when saving some files as dxf or dwg they do not convert the circles.
I've tried different options but have had no luck.
Re: save as dxf or dwg
Not applicable
Larry,
Can you send an example where this happens?
Rick B.
Not applicable
I answered my own question, this only happens when I have converted and old drawing
to dxf then made modifications and resaved it as a dxf drawing. The solution was
to replace the original circles with new Solid edge circles then it worked fine.
