scaling
Not applicable
I've imported a bitmap file and now I want to scale it to actual size before tracing
it. I measure the scanned image (using the measure tool) and it is 52.787 ft. In
real life the scanned image is actually 78.3 ft. I try to change the scale on the
Drawing Setup Screen from 1:1 to 1.4833 which should equate to 78.3 ft. but it does
not take (reverts back to 1:1). I am trying to use file, drawing area setup and
changing the scale 1:1 to get the real world dimensions. How do you change the
scale of a drawn object?
3 REPLIES 3
Re: scaling
Not applicable
Dave,
You don't need to use Drawing Setup to accomplish this. Select the image
and in the ribbon bar you will see the width & height dimensions for the
image. Just change one or the other to the necessary size. Lock Aspect
Ratio should be activated by default so chaning one should suffice.
David
"Dave Schafer" wrote in message
news:485fdbca$1@bbsnotes.ugs.com...
> before tracing
> ft. In
> scale on the
> but it does
> setup and
> change the
Re: scaling
Not applicable
"David Rieschick" wrote:
>Dave,
>David
>> before tracing
>> ft. In
>> scale on the
>> but it does
>> setup and
>> change the
Re: scaling
Not applicable
David: How simple it is when someone shows you the way! Thanks!
>Dave,
>David
>> before tracing
>> ft. In
>> scale on the
>> but it does
>> setup and
>> change the
