se 2d ST5 SElicence.dat
Not applicable
Hello. How do I get the SElicense.dat file to function properly on the newly installed version of SE 2d ST5 ?
thank you in advance.
Re: se 2d ST5 SElicence.dat
When you install the software the license is installed automatically. You should not have to manually apply a license. Are you getting an error when you run the software?
Rick B.
