security file
In solid edge, can it set security file?
And how to set password or security of fie??
Re: security file
Hi there @kanidtha,
To what end...?
Do you want to still be able to view & assemble the SE file but remove edit capablitiy? -or- to lock it away, so it can nolonger be seen & accessed without a password?
