small jogged without manually creating a contour flange
I jog.PNGam currently using 106.00.07.05 x64
I am unable to create a jogged flange smaller than the ((bend rad x 2)+.001). SE requires a flange between the to radiis. This can be done with using contour flange but that is not what i want. Has this issue been addressed?
Nathan M. Gardner
https://www.etsy.com/people/NathanMGardner
Be sure to check out my work!!
Made in Maine Wood Carvings
Re: small jogged without manually creating a contour flange
Hi Nathan,
To do a jog less than 2x bend radius, you will need to be in Ordered mode.
See attached image.
Hope that helps.
Michel Corriveau
