solid edge ST8 64 bit
hi everyone, please can someone help me with some tips how to install the solid edge ST8 64 bit. I downloaded 32bit but it doesn't work on my PC because it is 64 bit, and I don't know how to download the 64 bit.
Re: solid edge ST8 64 bit
Hi there @njonas,
I think you may have that the wrong way around......a 64bit application will NOT run on a 32bit OS [Operating System], but will work the other way.
I suspect your system is 32bit Windows, so getting a download link to ST8 will probably not cure your issue either, as it is ONLY available as a 64bit application. ST6 was the last version available in 32bit.
