solid edge st6 error
while opening solid edge st6 its showing an error msg.
plz help me.
am using windows 10 32 bit
provided the images of error
 plz help me
Re: solid edge st6 error
Solid Edge ST6 doesn't support WIN 10! You should using Solid Edge ST7 MP4 or higher or Solid Edge ST8!
BR,
Imics
any link for solid edge st8 academic/ students version?
Here is a link:
https://www.plm.automation.siemens.com/en_in/academic/resources/solid-edge/student-download.cfm
BR,
Imics
Akhil:
As I told you, you will get a response within seconds or at worst within minutes on the Sold Edge forum.
Best Wishes.
~Tushar
Hi there @AKHIL007,
Your problems are two fold.....you're on Windows 10, as mentioned, was not supported for ST6, plus your on a 32bit version of Windows. ST6 was the last release to be offered for 32bit operating system.
Probably not the news you'd hoped for, but I think the "best" solution for you, would be to upgrade your system to 64bit Windows, then download & install Solid Edge ST8 - Student Edition. Your CPU & RAM look adequate....assuming you have a suitably capable display adaptor also.
