solidedge bend edges
I got a short question, how do i draw a edge (in metal sheet) around a flenge?
See the examples in the attachment.
I tried multiple options but i cant figure out how to draw this in metalsheet (ordered)
Thanks!
Ruben
5 REPLIES 5
Betreff: solidedge bend edges
Hi @Ruben1
for me those pictures do not look like a "sheet metal" part in the sense of SE.
These parts more seems to be pressed parts rather than bended.
Wolfgang
Sorry that is what i ment. I work at a company where we work with bending machines.
But we want to buy a part from a press. Unfortunately we dont knoww how to design it.
Ruben
Hi @Ruben1
in that case I would do it as a part, modelling the shape as wanted and do a final thin wall to get it as "sheet part" finally.
PS.: You also can create the "platine" (flat pattern= of that geometry
Wolfgang
I will try that!
thanks for the advice.
Just for mine curiously, it isnt possible to make a continuous flange in SE?
Ruben
Hi @Ruben1
no, it is possible!
Yes, in Traditional only, but this is not that problem.
And Yes You als can create the flat pattern of it.
But IMHO I think it is easier doing it in part only.
But as so often, this only is a personal opinion
Wolfgang
