sort layer?
Not applicable
is there a way to sort layer?
for example the layer with dimensions or lines schoud be above the
textur-layer or other layers with "background-colors".
Robert
Re: sort layer?
Not applicable
Robert,
Currently there is not a sorting option for layers.
Adding sorting capabilities to layers is on the enhancement list.
Rick B.
Re: sort layer?
Not applicable
Am 25.05.2010 16:50, schrieb Ricky Black:
> Robert,
> Regards,
> Rick B.
OK.
meanwhile i will generate some empty Layers "between" and disarrange
Elements.
kind regards,
Robert
Re: sort layer?
Not applicable
> Robert,
please, if possible, put "copy Layer" on the enhancement list too.
Robert
