spurr gear need some help
I need a spur gear drawn up in ST6. i've tried the spur gear designed with out success, as usual, here's what i need 40 teeth, 5 DP, 20 pressure angle 8.00 pitch dia, 1-1/2 bore no hub. anyone help would be great Thank you
Re: spurr gear need some help
Hello TBD,
I've already switch to ST7 so my gear templates are updated and will not be useful in ST6.
If you want to build your own template, you can use formula in the attached pdf (page 1).
Also attached to this post, a parasolid of your gear.
HTH,
Michel
Humm ...
Can't post the Parasolid file.
Michel
