st7
I need help figuring out how to get something I made to go from part to draft. When I go to switch to menu it only wants to go to sheet metal. Is there a different way to do it or can I not?
Re: st7
If you have the part document open, simply go to the App button, New, and choose "Drawing of Active Model"
You can also start a new blank draft and use the View Wizard to insert views of any part you choose.
-Dylan Gondyke
