text size in hole table
Not applicable
how do I set the text size in a hole table? the table itself has good text size but
the text next to each hole to identify it is about 3 time larger than I want. How
do I change this text?
Thanks for any help
JT
Re: text size in hole table
Not applicable
The text next to the holes is the same size as the dimension text. If you
click on your table, the first field in your ribbon bar will be the style
used. Got to the Format/Style menu and choose that style, click Modify, and
on the Text tabe change the Font size field to the value that you want. Be
aware that anything else using that style will also be changed.
PellaKen
http://grundey.blogspot.com
"jt" wrote in message news:47c0da5a$1@bbsnotes.ugs.com...
> size but
> want. How
> Thanks for any help
> JT
