the error occured while solid edge draft environment to teamcenter
The error message " The new dataset cannot be attached to (name or code) because you do not have write-access. Consider revising the item or return to the new document dial..." appeared.. this message... appears when I draw part in the sheets and save them. How can I solve it?
Re: the error occured while solid edge draft environment to teamcenter
I am really sorry about my poor english.. I have changed revision information in property manager, but it was no use.
Did you change the status to released?
No I dont try it yet. I will try it! Thank you!
