threaded hole callout omits "THRU" for tap depth
All,
In ST9, we've noticed that when we dimension a threaded hole with a tap depth thru, the callout in draft omits the word "THRU" for the tap.  Both %ZT and %TD work this way.  Has anyone found a workaround for this yet?
Russ
Re: threaded hole callout omits "THRU" for tap depth
Nevermind,
I just noticed that the default for the thread depth THRU was set to blank.
All good!
