through face does not intersect path of the tool
Hi there
I'm trying to cut a part into slices using datum planes and the "trim body tool"
My work flow looks like this
-Body
-Datum plane at 39mm
-Trim body going up
-Datum plane at 38 mm
-Trim body going down
So I just want the slice between layers 38 and 39. This workflow works fine up to layer 38. At layer 39, there are some circular channels inside the part that make a sharp curve and I get the "through face does not intersect path of the tool" error
Thanks in advance
Re: through face does not intersect path of the tool
what Software are you using.. your screen shot does not look like Solid Edge?
Hi Matt,
Thanks for the reply. It's a version of NX. How exactly is Solid Edge different from NX?
Solid Edge and NX are 2 seperate CAD packages.
I see that you already posted this question on the NX forum...
http://community.plm.automation.siemens.com/t5/NX-Design-Forum/ct-p/NXforDesign
...so your answer will come from one of the users there.
Solid Edge and NX are both Siemens products but are completly seperate products...
good luck
Thanks! I take it the interfaces and ui are a little different?
