total weigth
Which variable gives me the total weigth of an assembly for use in a text-string or leader?
Re: total weigth
Mass, but you will need to expose the variable in order to use it as property text.  (FYI, new functionality in ST6)   http://screencast.com/t/tQlXHKgkX
Matt Johnson
Application Engineer
Ally PLM Solutions
matt.johnson@allyplm.com
http://allyplm.com/
