trasferring solid edge to my new laptop
N/A
Can someone please help me figure out what my next step is? I called Siemen's for help but they told me to get help from website. I need to switch my ST4 to my new laptop. How do I do this? I got a license notepad file but dont remember what I used for Key number. I tried to enroll again but never got an email. Help please my new computer has window 7 and is a 64 bit
Re: trasferring solid edge to my new laptop
Esteemed Contributor
Hi there,
Basically, if you have installed the program already, and you have the license file saved locally.....then you should have all you need.
What you want to do is copy the actual "SELicense.dat" file and paste this to the same location as the system generated place holder....by default, usually this is... "C:/Program Files/Solid Edge STx/Program" ... {edit} I should add,..."overwrite" the existing.
After that you should be good to go. Smiley Happy
Solid Edge ST10 [MP6] Classic [x2 seats]
N/A
At work and I'll try later when I get home. No sure if I made clear. I just downloaded file again from Seimen's PLM software I got on Nov. 1 2011. Is this still going to work. I get a file be used in another area type error.
N/A
Well finally home, and did exactly what you said and it works. Thank you
Most welcome.
