unwanted extra part created in Assembly Pattern
I am trying to use pattern to add press-in nuts and screws in a hole pattern. When I finish this there is always an additional object floating at the end of my model. I am unable to delete this. Thoughts? Pictures attached.
8 REPLIES 8
Betreff: unwanted extra part created in Assembly Pattern
Hi @ajrs269
without having the parts here for access is will be hard to give You the right answer or solution, but I can assume that the pattern in the master part itself will have 5 instead of 4 instances, could this be?
Wolfgang
I was using someone elses part and it turns out there was a 5th hole that did not appear in the model.
But, if this was a more complex hole pattern and I wanted to skip instances, would there be anyway to acheieve that?
Yes, it's in the pattern dialog.
Bruce Shand
Hi @ajrs269
if You supress pattern instances in the part pattern, they of course will be supressed in the asm too
Wolfgang
I'm on ST8. It appears my dialog only has:
Select Items Step
Select Part
Select Pattern
Select Reference Position
Hi @ajrs269
no, I'm not talking about the ASM pattern function but about the pattern within the part.
Here You for many many versions were able to suppress instances of a pattern.
If they are suppressed here, they also will not be used for the assembly patterning
There is no modification for ASM pattern in more current versions of SE
There is - of course - and this IMHO is one of the best enhancements of ST10 - the Clone Feature in ASM.
Simply click one reference hole and in any identical hole a clone of the parts will be positioned. Great!
Wolfgang
Gotcha
Thanks for the help!
Hi @ajrs269
welcome
Wolfgang
