Re: variable grouping in assembly
Pretty sure you can't.
Bruce Shand
@Buscetto wrote:
can I expose main variables in a draft table and make modifications without opening the 3d drawing?
This would again be the same un-conventional method involving creation of a new variable in the Draft which will drive one in the assembly which then exposed can make a return trip to the Draft in a Table title.
Ok understood, thank you all for your help
